A design originally created in MX SS2.
I am opening that genio file in MX SS4, In horizontal alignment its showing "Alignment brocken between ip".
How to solve this problem?
I am attaching a photo of the problem.
1. Why are you inputting the datatwice - you can see in the output window that strings are being renamed (as strings with that name already exist in the model).
2. Did the original alignment have back to back curves? Quick HA is only for IP based alignments.
Yes, original alignment have back to back curves.
You cannot use QHA for these. Major option ALIGNMENT is needed.
ok,
Thanks Sir,
