I am having trouble getting a level override to display on civil geometry in the drawing space. In the model space I can apply an override but it doesn't apply anywhere else.
Is there a solution to this?
Josh
Josh - are the Override settings the same as the ByLevel settings? For my GeomBaseline level, this is the case - so it does override, but with the same settings!!
Hi Mark,
The Override and ByLevel settings are now the same. The line segments of the centreline are now black but the arc segments are not. Also, the EOP geometry has not changed at all.
The arcs element template gives a colour, not ByLevel - you may have to change some of the settings.
Ok, I can take a look.
I would upload the DGNs but I am unable to post pzip files.
