Calculating terrain area with slopes
Hi
Is it posseble to calculate area of terrain with slopes included?
I am using OpenRoads Designer
Regfards
Sigfus
Parents Reply
  • Karon.
    It seems your template is 0.0003m thick, so you end up with a closed mesh. Your area is almost exactly twice my result as the area of surface template is both the top and bottom surface, plus the 0.0003m strip around the edge (this strip is not in my calculation.)
    I created a 'Mesh from element' and selected the original terrain - in the image below, I just moved the mesh (red) to one side. As you can see, Mesh = 17350.5 m2, Surface Template = 34701.3 m2
    I think the 'Mesh from element' is the correct workflow. (Please submit an enhancement for measuring area of terrain surface, as it is an obvious thing to want to know.)
    Answer Verified By: Sigfus Jonsson
