GPK Drainage - Show water and sewer crossings in profile?
This is the first project that I have used Water/Sewer on.  I am trying to get Drainage to draw the water and sewer crossings on drainage's profile views.  I am able to get the sewer crossings to draw but not the water main crossings.  The strange thing is that in my Water/Sewer file I am able to get the Drainage crossings to plot in the profile views.  I believe I have the correct symbology set up and I am pointing to the correct water/sewer file or else the sewer crossings would not draw at all in the drainage file.  How can I get the water crossings to plot from within Drainage?
This may be unrelated, but I am not able to get my water profiles to project onto a profile cell, and when drawn not projected (at a specific DP) they draw backward (to the left) as a mirror image of what I would expect.  The sewer profiles draw as expected.
Josh Mauritz
MS v08.11.05.17
GPK v08.11.05.39
  • Support is trying to resolve this issue.  They have my files and are able to get the water crossings to display on the drainage profiles, but then the sewer crossings that I was able to display disappear.  I have the opposite problem:  I can get the sewer crossings to plot, but not the water crossings.  I am anxiously awaiting their answer.
    Josh
  • It sounds like the water and sewer plan view graphics are using the exact same symbology, or something similar, such that the water & sewer lines are displaying the same and alternately confusing the profiler.  Also check your DDB file, water and sewer pipes, and make sure they're not using the exact same value in the attribute field.
  • Dan,
    I think we might be getting somewhere.  When I open a water profile, GEOPAK thinks for a short while (presumably generating elevations along the plan view element), but then all the options in the profile box revert back to some sort of default state.  I then have to open an existing symbology settings file to apply to each profile every time I try to edit them.  This does not happen in Drainage.  The first time I try to File Open a settings file Water and Sewer looks for a .wsp file.  I cancel the File Open dialog.  Then if I do a File Save As it tries to save a .ppf file.  I then cancel out of the File Save As dialog and immediatley do a File Open again, and now it is looking for a .ppf file, which I then select and open in order to set all of my settings for my current profile.  I need to do this on each profile as I open them.  Could the problem be that I don't have a .wsp file?  Even without a wsp file, WatSew is not remembering any of my profile settings that were last stored with the profile.  Each profile could theoretically have different settings, right?  All of mine are the same, but each profile's settings can be stored independently and don't need to refer back to a "master" settings file, right?
    Thanks for all the help,
    Josh
  • I've nested some responses below (hope the formatting looks right)
    >> the wsp is (should) only be accessed from the Project > Preferences, this could be the problem
    >> That is the correct file type.
    I then cancel out of the File Save As dialog and immediatley do a File Open again, and now it is looking for a .ppf file.
    >> Thats the correct workaround, but it sounds bad regardless, somewhere along it got stuck looking at the wrong file type and could be the root cause of the problem I would (if it were easy enough) a) delete the water line and profile b) save and close the files c) delete the resource files (*.rsc from the bin directory) and d)remake the water line & profile. If its still looking for the *.wsp instead of *.ppf, support should probably debug it. As Robert says, it could be a myriad of things.
    >> nope, you can run the program fine without saving or needing the *.wsp
    >> yep, each one could be set differently
    >> right, you could use one or many *.ppf and each could display the same or differently
    hth.
  • Dan,
    I found the culprit.  There were some lines in my custom configuration that were pointing to wsp files when they should have been pointing to ppf files.
    GPKHYD_DEFAULT_PROFPREFWATER = f:/home/pw/cad/geopak_v8i/preference/mfld_wat.ppf
    GPKHYD_DEFAULT_PROFPREFSEWER = f:/home/pw/cad/geopak_v8i/preference/mfld_sew.ppf
    Changing these lines fixed my strange profile preference behavior.  However, this did not fix the problem of Drainage incorrectly reading my WatSew project.  I'm still missing my water crossings, and my sewer crossings are plotting way too low in elevation.
    Thanks for your help,
    Josh
  • Hi Josh - that's great news!   'Funny' how three little letters can make a world of difference, huh?
    I think that any dialog that tried to open a WSP instead of the PPF, and any dialog that took information from the affected dialogs, would have its resource files corrupted; in turn causing the errant behavior on those dialogs & any resulting computations from those dialogs.
     Your safest bet would be to Line>Delete and Profile > Delete anything that was affected by the file type mismatch.  Then close MicroStation, delete the resource files again (*.rsc in the bin); then open and remake the previously affected components.  And it 'should' work again.
    Given all that, you may have to kick start some of the output, by issuing Lines&Profiles > Upddate All commands in watsew and Links&Profiles > Update All commands in drainage, just to play it safe...
  • Dan,
    With many, many thanks to Michael Gilham, it was discovered that the water/sewer dgn must be referenced into slot 1 of the drainage file for the crossings to be plotted correclty on the drainage profiles.
    Such a simple fix but certainly not an expected place to find it!
    Josh
Reply Children
