This is the first project that I have used Water/Sewer on. I am trying to get Drainage to draw the water and sewer crossings on drainage's profile views. I am able to get the sewer crossings to draw but not the water main crossings. The strange thing is that in my Water/Sewer file I am able to get the Drainage crossings to plot in the profile views. I believe I have the correct symbology set up and I am pointing to the correct water/sewer file or else the sewer crossings would not draw at all in the drainage file. How can I get the water crossings to plot from within Drainage?
This may be unrelated, but I am not able to get my water profiles to project onto a profile cell, and when drawn not projected (at a specific DP) they draw backward (to the left) as a mirror image of what I would expect. The sewer profiles draw as expected.
Josh Mauritz MS v08.11.05.17 GPK v08.11.05.39
Support is trying to resolve this issue. They have my files and are able to get the water crossings to display on the drainage profiles, but then the sewer crossings that I was able to display disappear. I have the opposite problem: I can get the sewer crossings to plot, but not the water crossings. I am anxiously awaiting their answer.
Josh
Dan,
Everything checks out. My sewer and water lines are drawn using different library items, each with unique symbology and attributes (double checked). I even deleted and recreated the offending water lines. They are visible as a file referenced to my Drainage file. I still have the same problem with Drainage only recognizing the sewer lines. However, in Water and Sewer, the drainage crossings show up on the water profile. This project happens to NOT have any sewer vs. water crossings, only sewer AND water crossings vs. drainage lines.
Thanks for you help,
I have occasionally seen projects which defy explanation and will not show some of the crossings. If you can call our support line and send your dataset will accomplish two goals:
Robert GarrettSenior Product EngineerBentley Systems Inc.
