Hi all,
I made the mistake of aborting (by quitting a session) after running the "Process all Objects" command from Explorer and now I have many (hundreds) of Linear Templates that are now Unlocked (Deactivated Rules).
Does anyone know of a method (keyin, command, etc.) to bulk enable/Lock Linear Templates/Corridors without having to either Lock in the popup menu or bucket? The Activate Rules command ("geometry element rules activate" keyin) only seems to work for Geometry.
Mark
I tried creating a macro to record the commands for a batch process, but was unsuccessful - was thinking you could run the command with a select all by level (corridor boundary) and locking the corridor - maybe you'll have more success.
Having the functionality for updating a federated model would be extremely helpful and time saving... would apply for bulk updating templates as well.
Justin Guiliano, PE
Rios Engineering, LLC
Hi Mark
Did you ever find a solution to this?
I'm having same issue currently, and can't find anything helpful in Commands or SDK for ORD
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
