Any input file to know the existing ground levels for 1) just under the proposed centre line & 2) at 15 m offset from design centre line on either side using MX Roads SS4 V8i ??
  • Create two lines at the required offset
    design,refs model
    100,mast,,cl00,7=-15
    100,mast,,cr00,7=15
    999
    Create a model to store the sections
    create,model 2
    Section the triangulation along the strings
    section,ground trian,refs model
    section,model 2
    177,mast,tx00,tc00
    177,cl00,tx00,tl00
    177,cr00,tx00,tr00
    999
    Take cross sections - labelled 'A' here
    at every point on MAST (173)
    or at defined interval (174)
    section,model 2,refs model
    section,model 2
    173,mast,,A,7=-20,10=20
    or
    174,mast,,A,10,7=-20,10=20
    999
    Delete strings if not needed
    edit,refs model
    004,3=cl00
    004,3=cr00
    999
    Report the points on the sections
    There will be 3 points per section - left, centre, right
    report,model 2
    992,a
    999
  • Please explain these commands:
    section,model 2
    177,mast,tx00,tc00
    177,cl00,tx00,tl00
    177,cr00,tx00,tr00
    999
    can I write above lines as below:
    section,TRIA 0 TO 15,DESIGN50
    section,model 2
    177,mast,tx10,CM00
    177,CML0,TX10,CML0
    177,CMR0,TX10,CMR0
    999
    (DESIGN MODEL=DESIGN50,DESIGN CENTRE LINE=MC00, TRIA MODEL=TRIA 0 TO 15,TRIA STRING-TX10,STRING UNDER MC00=CM00,string at 15m left offset=CML0,string at 15m right offset=CMR0
    what style set & feature set to give to model 2?
  • My 177 options are creating new strings Txxx - my model and strings names are only examples, replace them with your model and string names. I placed the new strings in a new model just to keep them separate from the design model.
    I did not assign any FNS/PSS to the model as I am only reporting it - you can assign what you like.
