I am currently using:
In Roads Suite V8i
V08.11.09.493
I am experiencing a problem that i cannot scale any object to a value < 1. If i select a value < 1 in the active scale dialog box it defaults it back to 1.
How do i get around this?
Kind Regards
Mohammad
Are you trying to adjust the active scale through the AS= key-in? Or are you trying to adjust some scale property on specific types of element, etc?
Not sure if you are using anything like the Global Scale factor or Text Scale Factor through native InRoads or if you are using straight MicroStation scaling.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/78161/text-scale-factor-not-working-properly/214422#214422
Mohammad, Are you using the scale tool in the Manipulate Toolbox? this works best for individual elements or a group of selected elements.
Idaho Red
