[Microstation V8i S4] InRoads Startup error "failed to load INROADS.3.1.DLL"
Hello all,
I installed the current version of InRoads (ir81109918en.exe) on top of my MicroStation V8i SS4 V08.11.09.862 running on a Workstation with Microsoft Windows 10. The Installation of InRodas works fine and finished without any error message.
When I have started Inroads the first time, I 've received a .net error. I eliminate it by commenting out the line with "InRoads_SS4=1" in file "InRoads.3.1.cfg" as suggested in https://communities.bentley.com/products/road___site_design/
After that MicroStation starts but in the end of loading a dgn a error message "Failed to load INROADS.3.1.DLL" appears. The new microstation menue entry "Application" is empty.
Can someone help me with this Problem? What's going wrong with the Installation?
Daniel
  • Hi Dan,
    Not sure if it helps with your situation or if it has been resolved. I had a similar issue and the reason on my end was due to having GEOPAK SS4 installed on the system, along w/ Microstation SS4 and inRoads SS4. After removing GEOPAK and re-installing InRoads, I no longer get the error message and I can actually see the "InRoads Group v8i" splash screen. Checking Applications menu shows "InRoads Group v8i" as normal w/ MicroStation.
    If you don't have GEOPAK installed, maybe another SS4 software is installed and conflicting with InRoads causing it to not launch properly? Hope this helps
Reply
  • Hi Dan,
