Hello all,
I installed the current version of InRoads (ir81109918en.exe) on top of my MicroStation V8i SS4 V08.11.09.862 running on a Workstation with Microsoft Windows 10. The Installation of InRodas works fine and finished without any error message.
When I have started Inroads the first time, I 've received a .net error. I eliminate it by commenting out the line with "InRoads_SS4=1" in file "InRoads.3.1.cfg" as suggested in https://communities.bentley.com/products/road___site_design/
After that MicroStation starts but in the end of loading a dgn a error message "Failed to load INROADS.3.1.DLL" appears. The new microstation menue entry "Application" is empty.
Can someone help me with this Problem? What's going wrong with the Installation?
Daniel
A little of both. Daniel never mentioned Ss10, only Windows 10. But I also know there were certain MicroStation V8i that we’re for certain verticals and we’re not recommended for the Civil vertical platforms. We started using Power InRoads instead of InRoads with MicroStation and are using Windows 10. But because we launch a single program, we have not had Daniels problem.
Hi Marc,
it's confusing me. The Bentley Download Service website provides only one installer for MicroStation V8i.
Where can I get the right InRoads installer for our MicroStation V8i (SELECTseries 4) environment (version 08.11.09.862)?
regards,
Hi Daniel and cadcop,
I'm not confusing SS10 and Windows 10, I'm just saying that InRoads SS10 (The version Daniel tried to install (ir81109918en.exe) ) works only with MicroStation SS10. If you go to the software download page and expand the arrow on the left you can see that the dependency is MicroStation SS10 version 08.11.09.912, screenshot below. If you can't see it or download it it's because this version of MicroStation is archived and therefore you have to download instead the release 08.11.09.916 of MicroStation which is available.
Daniel, as InRoads SS10 will not work with MicroStation SS4 and if you want to download an archived version of InRoads compatible with your version of MicroStation you need to raise a Service Request. But I'm not sure why you wouldn't upgrade your MicroStation toward SS10?
I was not aware that there was an InRoads Ss10 - is the also a Power InRoads Ss10?
Yes, you can download it here: https://softwaredownloads.bentley.com/en/ProductDetails/1862
