I've been trying to figure out what went wrong in my civil cell placement but to no avail so hoping that someone here could give a workaround / answer.
I used the default T Junction Civil Cell. After which i used the default Island Civil Cell. But for one reason or another the island is created with the fillet snap to the wrong "elevation" (refer to snap shots). I can't seem to find the way to edit or make sure the fillet is referencing the correct elevation (even when i go into the profile of the island)
Appreciate any help I can get.
Hi Chee,
This is a bug in 2019 R1 - definitely fixed for 2019 R2 due at any moment.
This is related to an issue with profile intersection points retaining rules when updated. You should be able to recreate those intersection points and update the profiles of the elements with issues.
Mark
Mark beat me to it. Not your fault, as I am sure that you have done nothing wrong, Chee. And yes, it is supposed to be fixed in 2019 R2.
Thanks guys! Will wait for the next update.
