I am using MX Road SS4 for Creating cross Section.
Can I change marked distance in attached crosssection drawing?
If Yes, then how?
Thanks to all in advance.
Do you mean you want to change the vertical distance between cross sections?
Answer Verified By: Mintu Mondal
Yes, I want to change vertical distance between cross sections,
how to change it?
Hi Mintu, have you checked the MX help?
Thank You for the help.
