Many users are still using InRoads V8i SS2 and we are trying to determine if Bentley has stated an exact date when SELECT Server licenses will stop working as the migration to Connection Client happens. Transitioning to InRoads SS10 is not viable for users still using InRoads SS2 because of the file format and workflow changes. Ultimately we will switch over to OpenRoads but I don't know that all agencies, DOTs, and clients will have transitioned by January 1, 2020.
Hi Joel,
I asked a similar thing recently and never got a response unfortunately:
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/181532/bentley-civil-v8i-ss10-update
Mark
I have also asked this same question....
Asked our Bentley Account Manager, Submitted a Bentley Support Request and I also called Bentley Licensing Support (Option # 3)
No response from Bentley
You'll notice, no answer here, either.
MaryB
I think one important thing to note here is that when the license pooling for the SS2 products is discontinued, you will still be able to use the products, it will just be licensed in a different manner. I do not have specifics on this transition or the exact date at this time, but more will be communicated before any change is made.
https://www.bentley.com/en/desktop-applications
This is the first time that I have heard about a potential alternate licensing approach.
Considering that this question has been asked by various people on various forums for several months, and all previous replies were either "don't worry about it" or "just switch to CONNECT"...I hope the specifics are communicated more clearly in the future.
Thank you for (finally) letting us know that this HAS been considered and that a "fix" is being discussed (at some level).
