What have been fix in this release?
Anything fix with DWG export?
What is new?
Here is a link to the What's New section of CONNECT Edition 2019 Release 2
https://docs.bentley.com/LiveContent/web/OpenRoads%20Designer%20CONNECT-v8/en/GUID-9CA386EA-84C2-4D4B-A6D9-8719E410B13F.html#
HTH,
Bob Mecham
There was a LOT of work done with DWG export/Save As. I would not say it is 100% fixed, but it has come a LONG way. In my limited testing yesterday I was getting really good results.
Could you say what are the improvements with DWG export/Save As?
I test export the profile to dwg.
Can anyone test this?
DGN
DWG
Hi Marc, I am still having this problem even in the latest version of ORD. It seems like this problem yet to solved.
Now with the ability to label crossing feature names in cross sections, labelling at irregular chainages for start and ends of each profile drawing, profile alignment name title annotation, export of profile 3d cuts to DWG, and more - delushionally waiting for Bentley to provide a Defects/Enhancement list like all the other Bentley software...
Mark
