What have been fix in this release?
Anything fix with DWG export?
What is new?
I think it depend how you generated those drawing model. If you generate your profile in the same file as your alignement you are fine. But if you generate your drawing model based on a reference file you get lost information. How was your profile generated?
How do you manage the labeling at irregular chainages for start and ends of each profile drawing? I could not figure it out?
Try using the Horizontal Increments along Horizontal Alignment option with a very large spacing (so no intermediate points are labelled)
I found this out by accident - I really wish this was communicated to the users. So much trial and error!
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Wow Thanks Mark It worked as a charm. I don't think it was intended for this use but it work perfectly. Thanks for sharing!
Hi Jeremie, I generate this profile drawing from the same file as my alignment and this was the outcome when i export out to DWG format.There is a go around solution for this issue by doing some settings on the reference options during the export process where I need to export twice with different settings each. Lastly I will need to combine both profile as 1 in order to get the perfect profile drawing in DWG format. This will be quite troublesome if many profiles needed to be exported.
