Is there a way to set the guardrail on a roadway template to display the post/bumper every 10' instead of like a wall without using a 3D linestyle?
Thank you!
Hi Taylor,
What is the software your are working with? Please include the version number as well.
Is there any follow up on this?
I think I'm correct here, but... The out put of running a roadway template is points and shapes extruded into 3D linestrings and mesh volumes. A single template will exclude these continuously along the template drop length. You could switch templates in a repeated pattern, but that would be hard to manage. the 3D linestyle is a technology that takes a continuous linear element and allows you to repeat a complex pattern longitudinally. I know of no other way to represent irregularity across a continuous linear element.
Jeff Martin, PE, Civil Consultant, Bentley Systems
Answer Verified By: Taylor Brownlow
That's what I am figuring out from research. Thanks for the reply.
