Error opening dgnlib file of custom workflow again in ORD
Add the dgnlib file of the custom workflow under 【C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\Default\gui\Archive】. Open the ord software to see the additional workflow tab; if you want to edit the dgnlib file again to add new tabs or buttons, When opening the dgnlib file, ORD software exits abnormally (the same error occurs when running with administrator privileges). The error message is as follows:
