Updating my workspace recently ive changed my setup to something that works well.
Set the MS_PERSONALDGNLIB variable in your workspace to your Custom Ribbon dgnlib so it becomes the default custom ribbon file and add this dgnlib to your MS_GUIDGNLIBLIST so it loads.
Then all you need to do is use the "Customize Ribbon" command to edit the Custom Ribbon in any file you're in (no need to open it directly).
This should avoid the mucking about with Users personal files (a workflow that I also despise).
Mark
Answer Verified By: xiangjun yang
The elegance of such a simple solution does not escape me. Thanks a LOT!!
Thank you very much. This is a good solution.
