A project has seed file of 2D of default design model, default sheet model & DPF sheet model. How to convert all these 2D seed to 3D in MX Road SS4 V8i?
Dear Amita,
please tell me the difference that will be made by the microstation setting change as shown in attached images.
The 'Project' changes the configuration so that it looks at particular folders for things such as seed files, level libraries, cells, feature definition libraries etc. The 'Untitles' project does not have anything defined - whereas the 'Metric' project has everything set up for a metric project.
A quick way to see the difference is to open a file with 'Untitled' as the project, and check what levels are available in Level Manager. Open the same file with 'Bentley-Metric' and do the same - you will see a big difference. Note - the DGN itself has not changed, but the libraries that you are pointing to have.
NOTE: as this is a completely different topic to the original 'seed file' subject, you should really create a new thread for it.
In this way to create 3D files, I would lost the feature definitions. How to keep the all feature definitions in 3D files please?
Frank - I do not understand your comment - if you create a 3D file, you will still have the feature definitions in the workspace library, so they will still be available. What software are you using?
