When ORD 2019 Release 1 came out we had issues getting the Civil Cells that were delivered with the software to work properly. To avoid the pitfalls associated with those Civil Cells we created our own. After a lot of study and trial and error I developed several stable cells that worked very well with our work flows.
We recently upgraded to Version 10.07.01.32 with the hopes that some of the bugs noted in previous versions had been addressed. Now the Civil Cells that I previously developed no longer work properly. It seems to have something to do with projecting profiles from one element to another. In previous versions of ORD if two geometry lines were at 90 degrees to one another you could project a profile at say 1.5% from one to the other and it would work. Now it seems like there is about a 50/50 chance that it will work. I also have a situation in one of the cells that I created where the angle between the lines is about 60 degrees and I can't get a profile to project. The lines even share a common end point.
I wanted to make sure what I was observing only happened in the latest release and not in the previous one so I went to a computer that had not yet been upgraded to the latest version. I tested the cell by dragging the control lines around trying to "break" the cell. I couldn't do it. Now if I open the cell in the most current version and drag the control lines around the cell graphics immediately fail.
Has anyone else noticed that civil cells are not working properly in the latest version? Has anyone had problems specifically with projecting profiles from one element to another?
Hi Christopher, thank you for the detailed workflow.
Unfortunately I was unable to reproduce the issue. It works fine with 2019R2 on my end.
Have you tried with no workset?
We can try to identify the cause of this problem
