IR SS2 drainage - No Flow found upstream
I am new to the drainage tools in SS2. I have created a small drainage network. When I run Network > Design, the design log states "No flow found upstream". I have areas defined and attached to inlets. The inlets show 0.00 for all the values on the Edit/Review dialog Flow tab, except Contributing Area.. I have the same problem for pipes, all 0.00's.
What am I missing?
Parents Reply Children
