There are some things that ORD is not able to do. No, really.
Eventually, someone in the trenches is asked to provide additional detail on a plan that ORD has no easy tool for.
Preparing construction plans often requires the labeling of point data of a construction item. In my case, it's a key point called out on ADA ped ramp details.
I can use the analysis tool to analyze a point on an alignment, which has an active profile, and "see" the sta., elev, offset, and slope info, but no way to place
that data in the .dgn for manipulation.
Furthermore, what I need (for possible field use) is Coords of the point, something the analyze tool does not report, to be included for the plan.
I can extract x-y data and place text using the (legacy?) Label Coordinates tool but it fails to recognize the ORD alignment profile connection.
I can't believe I'm the only one who still needs to do this, or who has trouble forming a successful search string to mine the data base here.
Any help? Thanks
Try placing civil points using civil accudraw with chainage offset and the place text and link it to the point using fields.
This should allow you to display chainage offset etc.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Thanks for the comment. I must first find instruction on Civil point placement...
