Hej
I am looking for best practice to deliver 3D CAD files (dgn) to our Client. We do not want to deliver native files with corridors definitions, as there are to many relationships, references, etc. We would like to deliver just the Default-3D model. The problem is that exporting just this Default-3D model will strip OpenRoads Civil Specific Data (Feature Name, Feature Definition, Start/Stop Stations, etc). Same with Copy Fence to File command or merging Default-3D to an external 3D file.
The solution would be to create imodel where the Civil Business Data is retained but unfortunately linear features that has originally gaps in the native model, once exported these gaps are being healed/closed with a linear segment with no vertexes.
I would appreciate any piece of advice.
Adam\\
ORD 2019 R2
I need to deliver just DGN with CAD graphic with assigned Civil Meta Data. Contractor wants independent DGN files, with no references, relationships, etc. They don't use ORD. They don't want to edit corridors, etc. Just single DGN per road/asset.
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
This is very interesting, for now I am lacking for example Novapoint capabilities to have Business Data export to the IFC. IFC seems to be more and more popular and we often have clients demanding this format.
Marc, you are right, that would be great but with ORD 2019 update 2, Display Clipped Graphic copy only the Cut/Fill meshes and will not copy my corridor components. I am sure it worked just fine with Update 1 for 2019.
it did, these regressions are getting ridiculous...
Mark
Mark,
Thanks a lot for your hint. Asset Manager along with Item Type Import/Export Instances governs.
