Hej
I am looking for best practice to deliver 3D CAD files (dgn) to our Client. We do not want to deliver native files with corridors definitions, as there are to many relationships, references, etc. We would like to deliver just the Default-3D model. The problem is that exporting just this Default-3D model will strip OpenRoads Civil Specific Data (Feature Name, Feature Definition, Start/Stop Stations, etc). Same with Copy Fence to File command or merging Default-3D to an external 3D file.
The solution would be to create imodel where the Civil Business Data is retained but unfortunately linear features that has originally gaps in the native model, once exported these gaps are being healed/closed with a linear segment with no vertexes.
I would appreciate any piece of advice.
Adam\\
ORD 2019 R2
Mark, Indeed...
The only problem is that Asset Manager Export/Import Instances tends to crash software when Item Type Definition is more complex (etc returns components volumes, surface... But in general tools are great. Now waiting for the IFC atributes to be enabled somehow.
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
Adam,
I tested this the other day in response to a different post by you. I was able to get the graphics to copy in to the new file without issues.
Marc
