Hi there,
I'm having difficulty displaying the pavement edge lines and elevations within the profile frame annotation box. And in the profile view. The edge lines were creating within a corridor and from a template drop.
This is a requirement from a Client and I can not find any tutorials or guidance on this.
Could you please advice if there are any tutorials?
Kind Regards,
Mark
This is what you need to do. The EOP needs to be projected on to the centreline profile
1. Edit the Annotation group to add an alias - this will pick up the projected EOP profile. In the image below, I have called it 'EOP' - I could have two e.g.Left EOP/Right EOP. Click the '...' to display the alias dialog, and add.
2. The Row Definition has 'Z along EOP' - set the text favorite to give you the required value.
3. When you annotate the profile, a dialog will appear giving you the choice of feature to use as 'EOP'.
In my example, my annotation box is at the bottom of the frame.
Answer Verified By: Mark Russell
Thanks a lot for this Mark. This has resolved my problem. :-)
Hi Mark Marnell the solution was helpful for the EOP elevations. I've been struggling to conjure up a solution for determining EOPs offsets from the active alignment. Could you kindly assist with the solution for determining EOPs offset and showing them on the profile. Thanks.
I have never seen a cross sectional offset being annotated on a profile - not even sure it can be done as everything is projected onto the chainage/level 'plane'. How do you do it at present?
Using SS2, I projected the EOPs on the road CL alignment. Then I annotate the EOP features' OFFSET and ELEVATION. The image bellow shows the final result.
