Has anyone had the issue with an idle warning showing up?
I have received this warning (below) from inroads if I leave a drawing open too long without working in it. This warning is not the issue, it is the second warning I get that shows up randomly.
this is what the other warning is (Below). Is this related to PowerInroads or independent. issue
when I log into my machine in the morning there is roughly 18-20 warnings to close out of before I can do anything and no Bentley product is left open over night.
My IT personnel have reached a point where they cannot figure out what this second warning is targeting.
Any help would be greatly appreciated...
Hi Daniel Yeagle,
Since the message you are reporting is respective to a specific "Product" (Power InRoads) vs. "Programming "(VBA, MDL, ...) reference, I am moving this post to the Civil product forum for future reference.
MicroStation and a number of other Bentley vertical market products provide an MS_IDLETIMEOUT capability and standard message.
The message you present does not match the one that Bentley products would show for this purpose.
When searching Google for the specific Message text used ("The Application" + "has been idle too long, please begin using it or quit now."), only one result is returned that points to the vendor(s):
Falcon/Hybrid-Analysis "malware analysis service" presents this exact message.
It would be advisable to check with someone in your IT/ITS department to determine if the 3rd party software is in use, can be modified (if needed), is required to meet any associated internal company/corporate policies and/or security measures in place.
HTH,Bob
