I would like to see my pop up menus come in opaque instead of transparent. Does anyone know how to remedy?
Thank you,
Katie Wade
It seems there is no way to modify it, do you want to file an enhancement request?
yes, please. That would be helpful i think. thank you.
Hi Katie,
Can you please check try the below solution
1. Go to "File > Settings > Preferences".
2. From the "Preference" dialog box, select the "Look & Feel" option. You will find a setting "Modeless Dialogs Transparency" check mark this and adjust the slider. 0 is Opaque & 100 fully transparent.
Attached is the image for your reference. Hope this helps. Do let me know.
