When I open DGN outputs created by OpenRoads the Text Favourites do not display in Microstation Connect. This affects all outputs including Long Sections, Cross Sections and Control Lines
I have tried using the same workspaces and ensuring that the Text Favourite Variable is mapped. However if I open the files with OpenRoads or OpenBridge with no workspace applied, I am able to see the text favourites. It is just Microstation Connect (Edition 12) where the Text Favourites do not populate with any data.
I am not sure I understand. Are you including the dgnlib with the text fav in the workspace? that should work
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/33435/openroads-designer
Hi Nico,
Thanks for your reply. Let me clarify,
Text favourites work with no issue in OpenRoads and ORD is mapping to the dgnlib.
It is when I try and open the ORD outputs in Microstation Connect that the text favourites stop working. MS Connect is also mapping to the same dgnlib with the text favourites in it.
i also have this issue, did you find a resolution?
Hi Mark,
I logged a ticket with Bentley and this was an issue however it has been resolved in Microstation Connect Update 13.
I have upgraded now and no issues.
Gentlemen:
So is MicroStation being correctly mapped to the Text Favorites file alone, or are y'all dropping the text in order for MicroStation (not ORD) to display it correctly?
Mark
