Hej
I am struggling with a 3D modelling outcome. I have a corridor, few km long. Using few templates with a number of components. Single Template (Name it Template A) is applied few times along corridor. With such approach I get a single mesh from Component (name it Component B) that is present in Template A. With this being said I have a single component mesh with gaps. Start Station and Stop Station fields are populated with values from the very first station when Template A is used to the very last one Template A application. I would understand connecting Components into a single mesh if templates are adjacent but when there is another template drop between the first and the second drop of Template A, I don't see any reasons for connecting meshes. Even If I copy Template A to Template A1, A2, A3 (...) but Component B has a constant name in all copied A components, I still get single mesh with gaps. The only way is to rename all the components, doable with a NotePad or any other Text Editor but I would rather avoid editing ITL in text processor.
The same result is when we have a single template but component is turned off and on along corridor with Display Rules. I got Single mesh for all instances where component is turned on by Display Rule. Eg. I have guardrail when embankment is higher than 3m. I have a single mesh with gaps, but the Start/Stop Station values are the same as for the template drop and not the when display rule turned on the guardraill component.
I tried to split meshes with Microstation Tool by Mesh Connectivity, but then all Civil data are stripped from the mesh. Mesh is divided, no meta data, two new Element IDs are generated and really can not use Item Types Import/Export Instances to fix CiVil data on meshes. Using Asset Manager would be helpful but tedious and time consuming and with Civil Data stripped mapping meta data would be tricky..
Is there a way to get separate mesh per component instances? Eg splited by template drops?
Is there a way to have separate meshes by components displayed by display rules?
Adam
Did you find a solution? It's posible to Split in different elements this component? I've thought using different corrridors, but it'l be time consuming
ORD 2022R3 ORDL 2022R3 LumenRT 16.17.59.94 Synchro 06.05.01.05
nope. I did not. However now we are working with asset manage a lot so splitting meshes with microstation tools by mesh connectiviti is acceptable.
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
First Question, Why do you need one long corridor? What is the benefit of one corridor?
If you do decide you need one corridor , Here is one solution to your problem. Edit the template drop after the gap and change the component name. Just add a "1" after the name. Do the same for the other drops. If the component have different names they won't connect. This won't affect quantities or graphical filters etc.. , all OpenRoads tools look for the feature definition name not the component name.
Zane Pratt
Civil Designer
with this approach you will have a number of templates to manage, change whenever Feature Definition or points's name are changed. Also, this single meshes affects components displayed with display rules.
Imagine simple road corridor, road template (A), bridge template (B), road template (A), bridge (B), and road template (A) - instead of having two templates you will need 5 just to have separate meshes. Actually you can have singe template and swithc road to bridge with display rules. Just an example.
In my original post I was explaining this workaround to rename components names, even with text editor.
On the other hand, we can use named boundary to split meshes as we want
I would respond to that saying you should try having 5 corridors with 2 templates. When your mesh problem goes away. I have had problems with corridors going through a bridge areas. If you try and grab features to create terrains the software will extend the gap or connect the features. You will end up with a terrain across the bridge area if you like it or not.
