I am trying to view the cross sections but only see the center node at any station. I tried deleting the cross section view from the civil display browser but it is not listed there to delete.The view worked last week. The only elements in this file are the corridor elements, where everything else is referenced in. Any thoughts? Thanks
Couple items: What versions? We did do a few fixes to prevent this from occurring, we are currently 10.07.01.32. Have you tried cutting om the alignment instead of the corridor? Does it show? Also--remember you can cut corridor section from a reference file but you would need to use the Dynamic Section tool from the ribbon to select the referenced corridor instead of the pop up menu.
Joe Waxmonsky
It doesn't display on the alignment or corridor cross sections. I have tried from the pop up and the ribbon.
It worked fine last friday.
I can view the cut/fill volumes fine
This article has a few things to try.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/42139/dynamic-cross-section-view-is-blank-and-missing-3d-components-in-openroads-designer
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
