I am trying to view the cross sections but only see the center node at any station. I tried deleting the cross section view from the civil display browser but it is not listed there to delete.The view worked last week. The only elements in this file are the corridor elements, where everything else is referenced in. Any thoughts? Thanks
Thanks, I tried all of those before with no luck.
Check that "ignore references when live nested" is not enabled, either for the 3D reference file or as a default attachment option.
It is not enabled in any of my reference files.
Something is weird because it wont let me select any of the elements that will display on the dynamic cross sections like cut/fill shapes.
Are there any other suggestions for this issue? I have even deleted the corridor and started over with no change.
