Load Field book from Graphics
Just getting started using ORD. There will no doubt be a large amount of data to migrate from SS4 to ORD.
Version info:
Problem: Load survey field book from graphics fails to assign correct feature code to linear features. All linear features are being assigned feature code ACU.
Graphic shows how and where I'm starting the workflow.
Results. All linear features are assigned a feature code of ACU. The graphics look correct even though the feature codes are incorrect.
The point features appear to be correct. No issue yet.
Any ideas?
Cliff
