In the help section off OpenRoads Designer CONNECT Edition it shows the options for Processing & Critical Sections (Corridor Feature Definitions)
Enable Clipping true
Enable Tunnel Boolean False
Could anyone explain the function off Tunnel Boolean?
Mark Bos
Hi Mark
I think it might be to allow for tunnel clipping in our corridors that should be a Boolean clip. See this SIG below around the 39 minute mark.
I am using the latest version but that setting doesn't appear I think it is hidden for us users....
https://learn.bentley.com/app/VideoPlayer/LinkToIndividualCourse?LearningPathID=112219&CourseId=128216&MediaID=5018222
Ross
Hi Ross,
that is a good explanation off tunnel Clipping. I't seems that there is a lot off information in those video's, would be nice if the video's where cataloged on topics.
Mark
