Has anyone else encountered this issue? It occurs when trying to use active chain control in PowerGEOPAK SS4.
delete your resource filesDelete everything under the 8.11 folder
C:\Users\ yourusername \AppData\Local\Bentley\powergeopak\8.11
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/15923/geopak-resource-files-how-to-remove-them-and-why
I did this and ACC loaded, however, when I selected the chain the same error message reappeared.
Justin Guiliano, PE
Rios Engineering, LLC
there may be a problem with the chain. can you select another chain?
No success with any alignments. GPK is hosted on PW - could there be an issue here?
yes, what version of pw? do you have the geopak user preferences > cogo preferences > job directory set to the pw location?
