Using ORD 10.070132 (just upgraded this morning to try to solve the issue below, but it didn't help)
I'm trying to drape a simple line to STM and I get this message: "Not able to drape anything with element 2"
Suggestions?
I've uploaded the data. The initial view appears as the above. The line(s) I'm trying to drape are in the REQD ROW level, parallel and left of the proposed pathway on the left side of the road.
Can you also send the STM file that you wish to use with the drape tool?
I'll upload the .stm file, but I thought it was an already an element within the ORD .dgn file itself.
Hi Andrew,
Try removing the clipped STM element first. Then use the Drape tool by selecting the lines required.
I deleted the clipped STM and tried to drape both remaining terrain models with two different elements. Still not working.
