I have a terrain, geometry, corridor and drawing-container i separate files and I am cutting cross sections using Named Boundary.
The terrain has a Feature Definition (and thus Element Template) making it grey:
The drawing container file has terrain, geometry and corridor attached to it.
When I cut Civil Cross Sections, the terrain shows as a grey line:
I would like the terrain line to be green instead.
So in the Default Model in the drawing contailer file I select the terrain and choose Overide Symbology and another Feature Definition.
The new FD uses this Element Template with Level Symbology of a level with green color:
But the terrain line in the cross sections does not change.
Changing the Override Symbology for the referenced Terrain file does not work either.
I have tried replacing the Terrain file with a copy where the Terrain has a "green" Feature Definition. This works.
But I do not want to keep a number of copies of my terrain for different display purposes.
So am I misunderstanding how to use the Override Symbology and how can I change the symbology of the terrain line in the cross sections?
Marianne:
I have noticed this issue as well. I created a "green" feature definition to make the symbology look correct, but this symbology is not native to the actual terrain model. I am certainly interested in following up on this thread as there must be a better manner of handling the issue.
Mark
