I have a model in openroads that was created off of imported geopak profiles. This model has been updated many times with this same gpk and it correctly replaced the previous profile. However, for some reason in the last two weeks when I import the new profiles, they show in the openroads file, are active, but the model does not follow them correctly. There are phantom lines that show up if you hover over them that show bits and pieces of the previous profile. The only solution thus far is to deactivate the new profile, delete everything, including all the old invisible profile lines, then reimport the new profile.
On top of this, some of the new profiles will come in only 80-90% correct. The elevations for each PI will be correct, but many will be on the wrong station. Again, I can fix this by manually selecting each PI and editing the station to match what it should be, but on a 5 mile long project, this takes time and leaves a large room for error.
The first picture shows the PI when imported into openroads from the gpk. Remember, this profile has been imported before and been fine, only minor changes have been made between each import:
This second picture shows where it should be based on the gpk, I manually edited the station to get it into place.
The third picture is the geopak output:
Here is another profile that shows part of the spline being relocated above some other points:
Has anyone experienced these issues?
William
I have had the exact same thing happen. I have imported Geopak profiles that have worked several times before and for some reason will not import now. They appear like they are importing but show no progress bar. I checked the Openroads profile against the Geopak profile and the data is not being updated. I have tried to remove the profile from the my model and import again and nothing comes in. It's almost like this information can not be redefined. I have also created a LandXML for the alignment / profile and it still does not import. Any help would be appreciated.
Mark
