Does anyone know if theres a way to display the Element ID property in the Properties dialog in ORD? It seems to have been removed from the dialog specifically for ORD for some reason.
Seeing that this is crucial for dependencies and relationship integrity it is something we really need to identify why object links get broken, etc
I tried the old CIVIL_SHOW_MS_PROPERTIES configuration variable, but it doesn't seem to display it either unfortunately.
Mark
Hi Mark, have you try the key-in: analyze element
Maybe it will give you what you want.
Excellent, that should do the job for now.
Thanks Jeremie!
Is there a list of the key-in commands anywhere?
Hi Mark,
what about attaching an Item Type with expression:
This.GetElement().ElementID
Wouldn't it work for you?
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
Thanks Adam, that would work, but as it's something Microstation reports in its properties normally, was looking for a way to just "turn it back on".
Seeing that Element ID is as important as ever in ORD, I don't understand why it has been removed?
