TMPLsurvey linking code has been extensively talked about both in InRoads and Openroads but I simply cannot find any example anywhere.
Can any experts out there help.
What file format to be selected to enable this to be processed?
Ideally I would want a video demonstration of the workflow involved here.
To help in answering this I have attached a file to be processed in OpenRoads.
5 497920.4418 145899.6095 39.889 CLRD ST TMPL EP1 3.75 -0.075 TC1 3.775 0.05 BC1 3.875 0.05 10 497924.4526 145896.6239 39.924 CLRD 15 497928.4634 145893.6384 39.959 CLRD 20 497932.4742 145890.6528 39.994 CLRD 25 497936.4853 145887.667 40.029 CLRD 30 497940.4958 145884.6817 40.064 CLRD 35 497944.6158 145881.8519 40.099 CLRD 40 497948.9852 145879.4252 40.134 CLRD 45 497953.5631 145877.4184 40.169 CLRD 50 497958.2041 145875.5579 40.134 CLRD 55 497962.8452 145873.6969 40.099 CLRD 60 497967.486 145871.837 40.064 CLRD 65 497972.0422 145869.7828 40.029 CLRD 70 497976.3591 145867.2647 39.994 CLRD 75 497980.481 145864.4346 39.959 CLRD 80 497984.5952 145861.5933 39.924 CLRD 85 497988.7094 145858.7519 39.889 CLRD 90 497992.8237 145855.9106 39.854 CLRD 95 497996.9854 145853.1409 39.819 CLRD 100 498001.3707 145850.7465 39.784 CLRD 105 498005.8718 145848.5653 39.839 CLRD 110 498010.3705 145846.3833 39.894 CLRD 115 498014.8657 145844.1939 39.949 CLRD 120 498019.3603 145841.9983 40.004 CLRD 125 498023.8519 145839.8066 40.059 CLRD 130 498028.3445 145837.6119 40.114 CLRD 135 498032.8377 145835.4175 40.169 CLRD 140 498037.3298 145833.2227 40.224 CLRD 145 498041.6591 145830.7592 40.279 CLRD 150 498044.2122 145826.5459 40.334 CLRD 155 498044.0568 145821.896 40.386 CLRD
Here is a wiki on the topic: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/13445/using-linear-feature-templates-tmpl-code-in-survey
Hello Marc,
I have already read this post on this community. I believe I do understand the offsets alocated to the various features. What is not clear is how this data is imported into the fieldbook.
I am not sure I can use TEXT WIZARD IMPORT. If this is the case, how are the horizontal and vertical offsets assigned?.
It may interest colleagues who want to help out that the sample data provided here are in the format of PNumENZCode. A video example would be very helpful.
Thank you.
Hello Augustine,
I created a txt file with the data formatted as showed below and then used the load data command:
5,497920.4418,145899.6095,39.889,CLRD ST TMPL EP1 3.75 -0.075 TC1 3.775 0.05 BC1 3.875 0.0510,497924.4526,145896.6239,39.924,CLRD15,497928.4634,145893.6384,39.959,CLRD20,497932.4742,145890.6528,39.994,CLRD25,497936.4853,145887.667,40.029,CLRD30,497940.4958,145884.6817,40.064,CLRD35,497944.6158,145881.8519,40.099,CLRD40,497948.9852,145879.4252,40.134,CLRD45,497953.5631,145877.4184,40.169,CLRD50,497958.2041,145875.5579,40.134,CLRD55,497962.8452,145873.6969,40.099,CLRD60,497967.486,145871.837,40.064,CLRD65,497972.0422,145869.7828,40.029,CLRD70,497976.3591,145867.2647,39.994,CLRD75,497980.481,145864.4346,39.959,CLRD80,497984.5952,145861.5933,39.924,CLRD85,497988.7094,145858.7519,39.889,CLRD90,497992.8237,145855.9106,39.854,CLRD95,497996.9854,145853.1409,39.819,CLRD100,498001.3707,145850.7465,39.784,CLRD105,498005.8718,145848.5653,39.839,CLRD110,498010.3705,145846.3833,39.894,CLRD115,498014.8657,145844.1939,39.949,CLRD120,498019.3603,145841.9983,40.004,CLRD125,498023.8519,145839.8066,40.059,CLRD130,498028.3445,145837.6119,40.114,CLRD135,498032.8377,145835.4175,40.169,CLRD140,498037.3298,145833.2227,40.224,CLRD145,498041.6591,145830.7592,40.279,CLRD150,498044.2122,145826.5459,40.334,CLRD155,498044.0568,145821.896,40.386,CLRD
I am very grateful for checking on me. I have tried your approach but then ORD opens another window to chose the file format. I have tried the many options opened to me but with little success.
Find attached a screen short of what was achieved.
Thank you and I look forward to your further comment on this.
I wish you would try it from your end to enable you share your results with me.
Thanks.
