Hello all
Is there an option to create a dynamic offset string that changes as we make changes in quick horizontal design in real time
(As i am also a civil 3d user there is an option "add offset alignment " in which the offset line also shifts as we adjust our alignment)
Thankyou
No, this option does not exist in quick horizontal design.
alright sir is there any other method to do the above
thankyou
You can design a string at the required offset once the horizontal alignment is completed.
Answer Verified By: Shivam Behl
Yes sir but the string doesn't change as i change my geometry , that means it cannot be done
Right sir
Correct.
