Hi all
We're busy working on exporting OpenRoads designs to IFC. Half proof-of-concept and half because we need to.
Corridors export okay (although definitely not perfect, InfraWorks can't handle the IFCs exported by ORD), but we can't get Subsurface Utilities models to export to IFC at all. Is there a way?
If not, what's the best way of get SUE models into an SHP format that includes all of the detailed information? Or even at all?
Kind Regards
You can export to a SHP file with ModelBuilder
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/2821/using-modelbuilder-to-import-external-data
Not being able to export Subsurface to IFC must be a defect and we will get it logged as such.
I have published the SUE model to an i.dgn to maintain as much information as possible. Then open that in AECOsim/OpenBuildings Designer and export to IFC using that. Not perfect but you get the 3D model and object id in IFC.
Working on linking metadata to the IFC file at the moment using the object ID.
Asset Manager in ORD will export to SHP too.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Hi guys,
did you were able to export aditional information contained in assets by using asset manager to ifc? If yes, how you did it? Or do you have some idea how to save and spread all aditional information from your models (building age, cost, material, etc. etc) to outer world? Thanks for tips.
Partially successful.
3 options
Hi Chris,
first step is ok, I can press a button:-), but by the next step begin some trouble. Please dou you have some example data which you can provide me and i can use them like learning example for me?
