Extracting utilities from 2D files
I am trying to get the hang of subsurface utility modeling in ORD. I have an existing utility 2d file and I have brought some underground storm lines into the 3d space using extract from graphic and filter.
How is the elevation data computed?
I assign the surface but the vertical offset is still below the terrain model. Drainage structure nodes automatically show up when a bend occurs but sometimes they are at elevation 0 and some pipes don't hit them.
Any advice or resources? Thanks
Parents Reply Children
