How do I show only used levels in the Select By Attributes dialog box? In the image on the left all the levels are being displayed and in the image on the right only the levels that have elements are being displayed and I'm trying to figure out how this was accomplished.
Hi Corey,
You screen shots show that you are using a Civil product (powercivil or Inroads maybe) not MicroStation.
Please post your thread in the dedicated forum https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum#pifragment-25841=1
Maria
I did a quick check in MSTN and Select By Attributes is only showing used levels in my case as well. I was thinking it may have something to do with an active level filter but that isn't the case, afaik.
~HTH
John.
yep
The 'Select By Attributes' seems to only shows levels that are in the current DGN (whether used or not), and any used levels from dgnlibs..
Answer Verified By: Corey Baird
