Folks:
I have attached an image of what is my issue. I imported an existing InRoads DTM into ORD, and while ORD has populated the level convention I have required, the text symbology seems to go to the default level. It is honoring the text style, but even when I force it to go to the correct level (see the properties box: "PR_DTM_Major_Contours_Txt"), it does not honor the color (see the level manager dialog). Furthermore, should there not be a text level setting for the contours in the CalculatedFeatureSettings within the element template?
I have tried this import in both a 2D seed file and a 3D seed file, but such makes no difference insomuch as this issue is concerned
What am I missing here??
Thanks!
Mark
ORD 2019 R2
Hello, it seems I have the same problem. When I import DTM, all calculated and source features are switched on/off differently from dgnlib and Level is Default. Josef
Josef:
What is even stranger than that- I have noticed- is that a "new" file with the correct dgnlib attached has its colors "scrambled". The majority of the colors in the dgnlib are not the same colors available in a newly created file. I have just finished up making sure that the same color table is attached to all relevant files. I do not know why such would make a difference, but it was the only thing that I could think of at the moment.
Well, it certainly seems to be the case that this software "cares" about color tables in some manner. Making sure that my seed files and my libraries all had the same color table attached solved the color conflict between a newly created file and the dgnlib. So, that is solved, but not my original questions. The contour text goes right to "default" and changing the property level to the- my- correct one does not follow-through with the correct color for that level.
Arrrggghhh...
