We are working with OpenRoads Designer 10.07.01.32 and producing plan and plan and profile sheet model with named boundary. I defined feature definition for the alignment and the ditches. When the profile is created ditches are annotated at each PI with sta and elevation according to road horizontal alignment Z value.
the thing is now, we want to manually move these annotations. Is there a way to lock/freeze so that it wont update if there is some modification.
Gilles
That almost did the trick! Well it worked for the annotations, but not for the frame.
Still a very powerful tool. I will have to work a bit with it and see if I can achieve also the frame.
Thanks a bunch MaryB for a very good tip.
You're welcome!
I'll be interested in seeing if you can retain the frame. I suspect that may not be possible - Base MicroStation cannot create notes with a frame like that. We've asked for years, but it hasn't happened. But I'll be intertested in seeing what you find.
That said, placing a few dozen shapes vs. having to recreate the labels gets you most of the way there. Happy to help :-)
MaryB
