Has there been any documentation provided for bringing text into Openroads? In the past for our note sheets we have either created a text box and pasted the text into the textbox and then had to reformat the text to have it appear correctly or printed the text to a pdf and then referenced the document into our note sheets. I was wondering if anyone had a more elegant solution? Both of the ways that I typically do it seem to be a brute force way of doing it. Thanks in advance.
I can think of several methods to achieve this, it depends mostly on how you manage these texts. You can create a cell and insert it in your sheets or have them in a dgn and attach it as a reference. You can also use the Text Favorites.
Here is an interesting post on a more complex way to manage your notes: https://communities.bentley.com/products/microstation/f/microstation-forum/182176/ce-new-approach-for-text-substitution
You can also use Item Types, see the help: https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v15/en/GUID-5662137D-989D-4E16-AE90-1A1D7D390245.html
