I am using ORD 2019 R2 for wind turbine platforms design. Site layout tools are great which lets closed profiles. However an iterative workflow is required for the platform arrangement. Is it possible to rotate and move the placed platform pad. For now it requires replacement of the pad. Is there any existing tool for the modification or any improvement of the application is possible?
You have to use the "Transform" command tools under the geometry ribbon (3rd from the right button). With this command you can move your pad around.
Answer Verified By: Erdem Atilir
Transform tools under geometry ribbon works only with drawn closed polygons under site layout. It doesn't work with parking lots, building pads and other pads. I have stared to use Site_Layout -> Draw_Basic -> Polygon tool instead. It seems fine for now.
