Modelling existing superelevation and showing within the schematic
I am wondering is there a way to show the existing superelevation of a road within the superelevation schematic drawing frame.
For example.
When using a corridor and applying a design super elevation using the superelevation editor this works perfectly. The schematic drawing and superelevation editor reflect the design intent.
If for example, the first section of the design is to match the existing road conditions, including horizontal/vertical geometry and crossfall, is it possible to show this within the superelevation schematic drawing?
For example, when using MX, the superelevation schematic takes the levels off the road edge string and calculates the crossfall. So if I were to drape the road edge string onto the existing ground surface, this would show the existing crossfall/superelevation.
I like using the 'Profile by slope from element' for smaller detailed sections. And some times, I have to work with imported 3D elements. However, it seems I wouldn't be able to show resultant superelevation/crossfall within the drawing.
I’d appreciate to know what others think of this.
Apologies for the confusing description.
Mark
