Hi everyone,
I was wondering if someone has ever integrated Autoturn to OpenRoadsDesigner 2019. Is there a tutorial available to do this ?
Regards.
Martin
According to the Transoft Solutions website - AutoTURN Compatibility Information - AutoTURN is compatible with the following:
Bentley® MicroStation® V8i, CONNECT®Bentley® PowerDraft V8i, PowerCivil V8iBentley® Power GEOPAK V8i, Power InRoads V8iBentley® AECOsim Building Designer V8i, CONNECTBentley® OpenBuildings Designer CONNECTBentley® OpenRoads Designer CONNECT
I would suggest you ask Transoft Solutions regarding a tutorial.
Hi Martin,
Heres some info I posted in the MicroStation forum a while back (its also valid for ORD):
https://communities.bentley.com/products/microstation/f/microstation-forum/174122/launching-autoturn-in-connect
Mark
FYI Autoturn 10.1 is required as a minimum for ORD 2019 R1+
Mark Shamoun
Thanks for the information.
Hi Mark, thanks for the information. Autoturn is now running in OpenRoads but I am still not able to intergrate it into the ORD ribbon.
I am working with the regular ToolBox but it would be good to have it in the ribbon. Have you ever face this issue before ?
