ORD > SUDA - Insert Node - there is no way to control rotation
Create a utility line such as a waterline
Start the insert node command to place a node along the water line.
Expectation is that rotation will be a function of the direction of the line to allow node to be placed, for example, at 90 degrees relative to the line direction.
Not only is it not possible define a rotation relative to the line but any input to the rotation field of the dialog is ignored.
